2024-09-26
10:28 AM
2024-10-01
06:26 PM
I have a dwg that I have attached some time ago to the archicad model file, and subsequently detached it, as I did not need it anymore. Of course now I need it again, and when I try to attach it, Archicad will not allow me. It says that the file name already exists. But when I check in the xref manager, the drawing is not there. It seems like that Archicad remembers the file that I have attached..
Is there a way to have Archicad forgetting the names of the xref files that have been detached?
2024-09-26 10:44 AM
Hey, it seems to be a bug a few years ago, but now when I tried with newer builds of Archicad it no longer happens. You may want to check whether you had the latest build installed?
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
2025-01-14 04:02 PM
I'm currently encountering this issue and I'm currently on the latest build of AC27 (6010)
2025-01-31 03:59 PM
I am also still encoutering this problem (today), also latest build of ArchiCad 27.
2025-01-31 04:01 PM
I was able to get around it for now by just closing out the file and reopening.
2025-01-31 04:23 PM
Thanks, that didn´t work form me, but I made a copy of the file I wanted to attach, renamed it and then placed it, and then relinked the file with the wrong name to the file with the correct name, that worked.
