‎2015-01-06 07:09 AM
‎2015-01-08 01:02 AM
‎2015-01-08 01:09 AM
‎2015-01-08 01:11 AM
‎2017-09-09 08:30 AM
‎2020-06-21 02:11 PM
‎2020-06-30 02:10 PM
paborges wrote:Hi Pedro,
Dear All,
I was wondering if you could help me with this issue. I am having the same problem, I can see all the information on the Xref manager, but I can't see the drawing. When I import it, I can see the rectangle showing the drawing size, but after the importation is finished, I can't see anything. I have already tried to open a new Archicad file and I have already tried many different AutoCAD files. However, I always have the same problem. Therefore, I think it is not a file problem, but maybe I am importing it incorrectly.
The dwg file is in meters, so I set the Archicad file in meters as well. When attaching the xref I leave the scale X and Y = 1 and in the translator settings, I change the drawing unit from millimeter to meter.
Could you please help me with this problem?
I can place the external content without any problems, reinforcing that it is not a file problem, but possibly a process matter.
Thank you very much,
Pedro
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-12-04 07:51 AM
‎2020-12-04 08:10 AM
toniski wrote:Hello,
Thanks! I had the same problem, and yes, the xref is all on New Construction Renovation Filter. But then how to change the Renovation status of an XREF?
Minh Nguyen
GRAPHISOFT
