Has anyone come across a way to list the area of zones as calculated AND as programmed? I have a spread sheet with a column that lists programmed areas and calculated areas. I have used the Zone No. line item to manually input the programmed area, which is not allowing me to sum the numbers i've inputted, though works graphically. The zones calculate just fine, as they are intended to. Even if I could manually input the programmed totals, it would help. Any other parameters that can be displayed in the stamp and a schedule that will total? I have attached an example of what I am trying to achieve.
Thanks in advance all.
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
