Zone Interactive Schedule Windows and Doors Not All Showing?
In my zone schedule not all my windows and doors are showing up. Is there something one must do with the zone fill to get the windows and doors all showing and to the correct areas?
My zone fills are touching the windows and doors but not all are showing?
Thanks in advance.
Regards,
3 Replies 3
Is it anything to do with the height of the wall base or window anchor in relation to the zone height?
i.e. is the wall base below the zone or is the anchor for the window outside the zone height?
Thanks Barry, Adjusted the zone height to 1800mm above the floor to catch most of the windows and doors but it still doesn't work. Some do and some don't show in the schedule. Very peculiar.
Mystery solved thanks to GS. The drawing had a couple of variations of a survey included and the zones were hitting the survey lines and not the walls in some instances and just missed points in other instances.
Once the zones were connected to the wall lines and intersections the windows and doors are nearly all showing up. Still having trouble with some sliding internal doors but I will get to the bottom of it.
