First you will need to tick the box in the schedule settings that says "Show uniform items as a single entry".
Now the trick is to make the 'unique' zones you have to be all the same so that can add together.
First you will need to remove the 'Home Storey' field as they are all on separate storeys so this will create a unique value - we need to get rid of that.
Next you have a field for the zone number.
You will either need to remove that or make sure each zone on each storey has the same zone number.
The same will apply for the zone name - it either needs to be the same on each storey or you need to delete the filed and not include it in your schedule.
Of course each of your units can hav a unique name (unit 1, unit2, etc.) or unique zone number but they must be the same on each storey otherwise they can't be grouped in the schedule.
