Zone info doesn't show for slabs in Schedule
Why won't the slabs list their zone information like any other object/wall beam in AC.
See the attached view.
The 3d window shows a wire frame zone with a beam(ID: STN-xx), object (ID STN-) and a 3" thick slab (ID: STN-2) which doesNOT list its zone info, unlike the beam and object.
Why not?
And since I'm asking, I found parameters to list the area of the slab, and the area of the hole, but no way to combine them.
Similarly, Is there a way to multiply a cost/sf by an area and put the result in an adjacent column? Such as
$10/SF x 48 SF = $480?
Don't bother suggesting exporting to Excel, that takes the fun out of it.
Thanks.
PS I bet Revit handles this flawlessly.
11 Replies 11
2021 here, is this possible now?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
I tried this, and in Archicad 24, if you schedule Slabs, the "Related Zone Name" and "Related Zone Number" schedule fields correctly return the info about the Zone the Slab is located in.
