Zones and Door/Window Schedules...Again
Dave Jochum
I'm so sick of this problem I could...never mind. I have a PLN that simply will not return all (it does some) zone locations in the door and window schedules. I've tried all the *bleeping* workarounds we've been forced to use for years including enlarging the zone boundaries beyond the enclosing walls, flipping markers, cutting and re-pasting zones, etc. Has anyone found a solution? Is it maybe fixed in 17? I haven't opened this project in 17 because I'm close to finishing CDs.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
13 REPLIES 13
Eduardo Rolon
Bitten by this bug yesterday. Was able to force some of the windows in the schedule to refresh, there was one that never did.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
How is a zone associated to an element?
In the case of a window, is the association with the wall element or the window object?
Ben Cohen
Hi Schmidi
I have looked at your file
At first I thought it was the way you had used walls to make your model (you have 7 walls in places that could just use one new composite). But this was not the problem
I noticed that the interactive scheduler would pickup the zone, but the window itself would not.
So I scripted an ArchiCAD window (so I knew it was not a 4D Library issue) to show the zone in plan - and it would not show the zone unless the walls and zone were at zero to the project
I then changed the wall projection to 'symbolic' and the zones started to work
The fix is to set all your walls to 'Symbolic' in 'Floor plan and section..' within the window and doors settings.
This is definite bug. I will report it to GS.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Thanks Ben for looking into this problem and providing a solution. Thanks to everyone else who have put thought to this issue. Yes, the new composite method is one I am very keen on but hard to sway others to adopt.
This works:
Change Wall containing problem window in ' Wall Selection Settings > FLOOR PLAN DISPLAY ' from std (mine is ' Projected with Overhead ' to ' SYMBOLIC CUT '.
The Zone element now provides correct data to schedules, inbuilt and 4D.
Thanks again.
