animation path to artlantis
I used create animation path in archicad and it used to export to artlantis file without problems, now I loose the path why exporting.
(I do have checked to save perspektive cameras, in old projects I can see the path created in archicad, but whatever project I create new, I don´t see the animation section in artlantis, I tried that on an other computer also, it used to work there too, but now it doesn´t)
Do you have any idea, why is this happing ?
1 Reply 1
Djordje
Don't Save as from the 3D window. With the 3D window active, choose Create walkthrough, and choose Art•Lantis format as the output. Set everything else as usual. You will probably have to adjust the path somewhat.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
