2004-06-14 10:10 PM
2004-07-02 09:19 PM
Lucy wrote:Don't Save as from the 3D window. With the 3D window active, choose Create walkthrough, and choose Art•Lantis format as the output. Set everything else as usual. You will probably have to adjust the path somewhat.
I used create animation path in archicad and it used to export to artlantis file without problems, now I loose the path why exporting.
