archicad-scia engineer-archicad
Hi!
can anyone help me with something; i've been trying to open Archicad model in Nemetschek Scia Engineer (i've saved it as .ifc) but i have problems with axis alignment. when i open model in scia, axis are ALWAYS in the middle of the object (slab, wall, beam..) even if I set them eccentric in archicad.
When i work in scia it is important that all axis are connected.
So, is the problem in modeling in archicad or in ifc exporting parameters?
I've attached image of the problem.
Thank you!
Sandra
1 REPLY 1
alemanda
...same problem from archicad to Robot Millenium (RSA)
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
