area of sloped roof
How do you calculate the actual roof area of a sloped roof. I've tried many things with zone SEO upwards, downwards, with adding additional parameters such as bottom zone area but nothing works.
4 Replies 4
David Maudlin
Robi:
I think you should look at Interactive Schedules for this task. The Roof has various area options (Gross, Net) for surface areas.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
The simplest way is the Element information palette
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Although you can get the info from Element information palette, I want it to be on my layout with the other calculations. So I took your advice David and made a new scheme not based on zones but rather on roof and it works like a charm. I really don't know how I missed this one... Thank you both!
Djordje
Yep, IS would be the way ...
Djordje
HP Omen
