block naming after dwg export
I'm hoping someone has experienced this who may be able to offer some insight. I'm not quite sure if it is a GDL issue or export translation.
After exporting to a dwg I've got
Name-Of-Archicad-Object_19
Name-Of-Archicad-Object_27
The numbering does not appear to be consistent, that is, when I move the object and export again it gets another number!
I could almost understand this if it were different in size, layer, content or something but even if it is the same identical object just copied.
As one can imagine this is insane when editing the dwg. Originally I thought it was this strange Auto ID Increase. The translator is set to Explode complex ArchiCAD Elements.
Looking forward to your puzzled responses!
0 Replies 0
