composit wall info
is there a way to extract.... print... view... create a scedule of composite walls....or merely view the information attached to composite walls.... need to be able to list/edit parameters (further than the wall list)
tried the wall list already... not sure how to organize or edit the info given here (ie: fill, volume, height, area, ect. <---- how can i +/- categories listed to edit to the ones i need)
perhaps it was a lack of pre-thought.... but this 15 story building has A LOT of walls..... i have created the 20 different wall types on a separate drafting story in hopes i could use this to lighten the load of what the program has to go thru to extract the info i desire....
is this even clear what i am asking for?
h-e-l-p
1 REPLY 1
No?
But, read the doc "Calculation Guide". I think you are looking for what is called property objects or property scripts.
