Jdawgz
Explode composite/complex walls
When joining several composite and complex profile walls with curves, the line work and connections get super messy despite material priority and junction order. It would be great if for these complex parts to 'right click' and 'explode' the composite into their individual elements and fix/connect manually rather than create a whole lot of walls to fix.
Steve Jepson
Yes. Long time request for Composite Wall Skins be individually adjusted, then locked together again.
However, if it's just the geometry you want,  you can explode a complex profile into a morph.  What used to be the wall skins are all together one morph, but you can adjust what used to be wall skin individually, and it will remain as the one morph.
https://app.screencast.com/Q35Q2J2m4e3Rc
  not the best example but good enough to show the idea.
