cover fills in door/window schedules
Tom Krowka
How can I eliminate glass fill in door & window schedules. Assumed it would be through schedule graphic over-rides. Have indicated door and window to have transparent fill but doesn't seem to do anything. Prints as a black block instead of only lines.
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
1 REPLY 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Tom,
Thank you for the report and I am sorry about the issue!
I'm not sure if the issue is still relevant, but could you share some more screenshots of what you want to achieve here?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
