curtain wall panel 2d view
Hello everyone,
I just make a curtain wall with custom panel shape
when I tried to schedule it I can't to get 2d front view of panel , only axonometric ones
is there any way to do that.
thank you
6 REPLIES 6
I've created my own curtain wall panel
I've done a schedule to put all "Library Item Settings" of my custom panel
There are all settings I've found ....
No 2d view found
Perhaps there is another way to find it
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Thank you. It seems no way to do that. And I wonder if I can change the direction of axonometric view to ge elevation from it.
Thanks
Ok
And did you try to custom these view since the schedule ?
I remenber modify 2D window view since my schedule to add of modify graphic appearance
Christophe - FRANCE
I can't modify this. Just add some annotations.
I found 3d front and 3d back view .it is work in some way..
I was thinking about adding a "Patch" over the original drawing to cover it while maintaining a personalized and dynamic design
To create a Patch "documentation/annotation/create a patch"
Christophe - FRANCE
Yes, these are your elevation views.
