lagodue
custom text fields?
In my components lists I am trying to add custom text fields, which do show up in the list. However, they are locked and I cannot enter any text. Any ideas?
Thx
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
1 Solution
It could be that the layer the elements are on is locked or hidden, or the elements themselves could be locked.
When you select that row, there should be a warning at the top of the schedule screen next to the buttons for selecting elements in plan or 3D (these will be locked as well).
Go to post
4 Replies 4
poco2013
Mentor
need more info -- I assume you are using the list schedule and not the interactive schedules?
If so, custom text fields are just a mater of adding a column and filling in the text. Obviously, this is not what you are referring too, so a screen shot might be helpful??
Gerry
lagodue
I have no problem with this custom text field for my door and window schedules. For a components list I am getting the attached, where any text entry is locked out.
lagodue
Great! Layer was hidden. All is well.
