daily construction update
Hi
I m a construction manage. I want that daily construction update (specially civil work) will be recorded in archicad. so that in future I can see in which date what I have done.
Say in 01 march 2012 I have constructed middle part of mat foundation. 02 march 2012 made retaining wall in one end.
sequence of work will be recorded by date. is it possible? if possible then how. if not possible then is there any solution for this kind of job?
thank u all
There is an add-on (Goodie) for Archicad called "Construction Simulation".
It can be found in the HELP menu by following the Archicad Downloads link if you do not have it already installed.
I have never used it but you can record start and end dates for the various construction elements.
I know you can then generate a movie of the construction but I don't know if you will can generate a usable list like a report of what was done when.
thanks for the information
