door schedule - orientation text
alemanda
Hi all,
I'musing the ITA version of AC16.
Is there any chance to change the orientation text from Italian (S and D) to English (L and R)?
I don't know ... maybe in the registry key ...
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
1 REPLY 1
There is no registry key that I know of - but that doesn't men there isn't one.
There are keys for special symbols - East (E), West (W), degrees (°), etc.
As far as I know it is only controlled in the object script.
You will need to open the object and go to the 'Compatibility Options' (version 16 & 17 or 'Details' in older versions).
There you can change the defaults - it will change to a 'Custom' value.
You will need to do this for every door and window and save the library part.
The problem is if you are using Graphisoft or 3rd party windows then these will be reset if you ever update them.
