dxf-dwg translators missing
Bob Moore
I was using publisher in AC 11 when I received a failed message. When I clicked on it I received the following pop-up: "dxf-dwg translators missing".
I've been using publisher since AC8 and this is the first time I've seen this.
Any clues on how to fix it? I searched the manual with no luck.
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
11 REPLIES 11
David Maudlin
Bob:
If you go to the DXF-DWG Translation Setup dialog box, you can use the Browse... button to navigate to this folder to load the translator(s) you need.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Bob Moore
David,
That seems to have worked,
Thanks.
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
