getting dxf import to show in
Hi folks!
I can import a dxf file into archicad, and the mesh shows in the floor
plan, but not in 3d window. Is there a way to rebuild mesh objects
into solids to that they display in 3d? Thanks in advance.
4 REPLIES 4
Djordje
Ace
O.k.
I went thru this article but when I import my geometry as an object it gets triangeleted, altho it was first an .dxf file without any triangles.
Is there an possibility to avoid this unecesary meshing when imprting .dxf files?
Also is there an possibility to define the imported objects as windows/doors, as you could when making objects inside AC?
Can anyone give a hint how to avoid this unnecesary meshing?
