how to crash archicad
found a bug that results in archicad crashing
change window height to 0
12 Replies 12
Luckily you shouldn't need a zero height window too often.
I can't get this to work with Cadimage windows. They just default to 1500 high. Hopefully there is a fix in future releases
What window are you using?
I just checked some of the default Archicad Library windows and they all have a minimum height built in except for the storefront windows - they just generate an error on 3D and don't display but it doesn't crash Archicad.
this is using cadimage windows AC18
2 workmates replicated it, I dare not try myself
You're right. My previous test was in AC16. AC18 freezes. Have you let Cadimage know?
yes i created a new ticket outlining the bug,
also complaining about the more convoluted menu system for the
cadimage door & window builder (in version 18 )
you have to go through about 10 different tabs just to change all the materials of a window to be the same, its worse for doors
10 different menus to change the different fill types and they are scattered about all the menus
same for pen types scattered through the menu
they need a new interface re-design
rjwilden
A new interface??? Don't say that they change it every 2 years. You just figure out where everything is and then someone has a great idea to change it all again. I have been using it in its various forms for 16 years, and It still annoys me.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
It is very annoying, I was beginning to think it was me being fussy or retarded!
Looks like a southern hemisphere only thread!
