importing organic rhino .dwg model into archicad's library
objective: tryn to create an organic form & and then have archicad document it. what's the best route to do this?
importing a rhino model as a .dwg into archicad library:
because last month..i modeled a mesh bridge + surfaced cocoon in a rhino scene> saved the scene as .dwg> opened the .dwg model & saved as a GDL
object in the library.
everything was great until i discovered that it wasn't showing the surfaced cocoon:) then i opened the file a wk later and Voilà..the cocoon
decided to show...hmmm. did i do somthing right by accident?
If Rhino can save 3DS it will probably give you a much better result.
