interactive elements
i have recently been given a project to draw a sales center for residential homes and i needed a ceiling fan. my boss will not lety me down load any elements so i have no ceiling fan. i entered the electrical symbol that came with the software. i cannot get that to come up in any of the schedules i am using to show electrical objects. can you help? i just need it to show up in the schedule.
6 REPLIES 6
Hy,
You can try in the standard library in the mechanical library at Heating and air conditioning
Best regards
Ede
There are no ceiling fans in the standard mechanical library under air conditioning or heating
Sorry, I think I misunderstood you, if you want a fan like in the image below I can attach for you the object, but if your boss doesn't let you to download it you can make it easily using profiler (for the ellipsoid) , basic shapes (a cylinder and a cone) and the wings from a thin slab
Regards,
Ede
this is a good idea. i haven't thought of creating it with shapes. thanx abunch.
This is an object from AC 7.0. The Lights (called "Lamps" in Parameters) can be turned on or off, as well as number of blades specified (3 to 6).
Jay
Jay -
Can you please email the object to which you referred? Do you know if it will function in AC14? Thanks much.
Joe, jcohen@cybermesa.com
