β2005-01-24 07:27 PM
β2005-01-24 07:31 PM
Rick wrote:Publish to DWG the views from ArchiCAD, not from PlotMaker. He will also get circles as circles (in the plans), dimensions as dimensions, etc.
A client is finding to work on a set of my converted plans in Autocad they are having to explode the "blocks" which means it might be quicker to redraw them than to alter them... so that's not good. He is not an autocad master, so he might be missing something. I was using the basic default translator into autocad 200
β2005-01-24 07:45 PM
β2005-01-25 01:49 AM
Djordje wrote:Of course, then his section markers all say PMAshNo or something silly instead of mentioning the proper drawing and sheet number...
β2005-01-25 01:33 PM
Karl wrote:The Placeholders can be turned off in the Section/Elevation dialogue box under the Marker tab (see picture) but as Karl said... it still won't show the drawing and sheet number.Djordje wrote:
β2005-01-25 06:59 PM
woodster wrote:Right ... but if you turn them off, then your exports from AC may look "OK" (although no numbers), but your prints from PlotMaker now also have no numbers and are not usable....you have to go back and change all of those settings for all markers again... floor by floor, section by section (detail markers), etc.
β2005-01-26 01:25 AM
Karl wrote:Wasn't disagreeing, Karl.
As I said, no perfect solution that works for all requirements.
β2005-01-28 07:42 AM
Karl wrote:I can't see why the placed drawings from PlotMaker come as blocks; even when you explode them, they explode in a rather crazy way. And, the sizes are HUGE - and average computer cannot handle that.woodster wrote:Right ... but if you turn them off, then your exports from AC may look "OK" (although no numbers), but your prints from PlotMaker now also have no numbers and are not usable....you have to go back and change all of those settings for all markers again... floor by floor, section by section (detail markers), etc.
