keynote scheduling
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-08-10 08:03 PM
After working in AC for nearly 20 years, I decided to make my first foray into keynote scheduling. I spent 30 minutes and built a schedule that reads two Property Values that I created ("keynote" and "keynote number").
To test, I assigned values to three elements - a column, a slab, and a wall. I labeled two of these elements on the plan, but did not label the third.
First question:
Can I set up the schedule so that IF an element does NOT have a label associated to it, THEN it will not show in the schedule? Many elements show in various views, but I do not want the keynote to be listed just because the element is in the view.
Second question:
Is there no way to "top justify" the cells in the schedule?? We often have very long notes, and "center-justification" is not only graphically inferior but also less clear.
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
- Labels:
Data management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-10 08:04 PM
13.2 macOS Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 12:01 AM
The way I would have gone about it is this...
Use ELEMENT ID for the KEYNOTE NUMBER (with the ability to override)
Place an AUTO LABEL that reads the keynote number
In the script of the note, have an external file that lists all the notes and numbers and have it perform a simple lookup to extract the note..
(Bonus, you could have a 2nd set of notes for the same number so one could be long and the other short and you could read either one by a switch)
So what happens is the NOTE LABEL itself gets injected with the actual notes.
The bitch is that ArchiCAD (after 33 years) CANNOT SCHEDULE LABELS!!!!
In essence, you could do the same thing by making the LABEL an OBJECT and read those... It just can't ASSOCIATE itself to the thing your pointing at.
I had just posted the sentiment elsewhere on this forum... (and I also posted it 3 years ago and 5 years ago...).
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 12:04 AM
Not sure I like the monthly fee idea though...
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 12:11 AM
I knew when I posted that it was an issue of AC being able to get 95% of the way there.... only to have it fail at the last 5% making it useless.
So close, yet so far.
13.2 macOS Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 12:15 AM
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 11:10 AM
vfrontiers wrote:Duane, you make that sound easy! Care to elaborate? I have an excel file I would love to link with a simple look up.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 03:39 PM
Page 560 in the current(AC21) GDL manual is where I'd start. The section called TEXT I/O... and in this case the subheading READING VALUES...
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-11 05:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-12 12:33 PM
