ā2019-03-28 11:12 PM
ā2019-06-06 12:41 PM
| Archicad 4.5 - 29
| HP Z840 | 2Ć E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
ā2019-06-06 02:49 PM
ā2020-01-20 10:43 AM
ā2020-01-21 10:51 AM
ā2020-01-21 11:09 AM
stefan wrote:The risk with this method is that the project can be placed very very far from the absolute origin, which irreparably causes errors in displays in three dimensions among others.
Can you ask the city to provide you with a DWG file you can use as reference with origin properly set up?
ā2020-01-21 08:40 PM
ā2022-04-11 03:52 PM - edited ā2022-04-11 03:53 PM
Any solutions yet on this topic? Would like to know a solution/workflow for georeferencing a 2D plan in Archicad and exporting it to DWG. Maybe there are add-ons available to do this?
ā2022-04-12 10:07 AM
Step 1: import a 2D site drawing in Archicad on a worksheet (that conforms to the needed coordinate system / norm)
Step 2: add your building contours to this worksheet
Step 3: save as DWG
This works fine for us.
There are many coordinate systems in use worldwide, so there really isn't one fixed solution I would guess.
ā2022-04-14 10:23 AM
@Erwin Edel , thanks for your feedback.
Just also found this workflow using the new Native Survey Point, we are testing it now. Works only in AC25. Apparently its useful for IFC as well DWG exports. Don't know yet if it also works for lay-outs that uses drawings from worksheets.
