new rendering engine, Octane Render
Here is a new rendering engine that you guys might be interested in trying out, a demo is available.
I recommened watching the video demonstration, very impressive!
http://www.refractivesoftware.com/index.html
Octane Render is the worlds first GPU based, un-biased, physically based renderer. As opposed to the handfull of processor cores available in CPU's, the GPU typically has hundreds of cores for parallel processing making it the best resource for rendering in your computer. Yet, to date no other software makes use of it in the way that Octane does. With even a single mid-range GPU you can typically expect to see a 1000%-1500% (10X to 15X) speed increase over a typical un-biased, CPU based renderer.
10 REPLIES 10
Please do the same render with artlantis and give a time-score to compare . I think that artlantis is better . Please do a comparative benchmark .
