plan view in door schedule
alemanda
Is there a way to have the casing (inside and outside) in the plan view in door schedule?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
You will need to play around with the object scripts.
See this post for an answer - you may need to follow some of the links for more explanation.
http://archicad-talk.graphisoft.com/viewtopic.php?t=35888
alemanda
Thank you very much!!!
I solved my problem.
It was enough to change the parameters bShowCasingOnLists in the macro WallHoleframing.gsm and that's it
Why doesn't GS implement the option to show or not the casing/sill/board in the lists for doors and openings?
AC27 latest hotfix
Win 10 Pro 64bit
