alemanda
plan view in door schedule
Is there a way to have the casing (inside and outside) in the plan view in door schedule?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
You will need to play around with the object scripts.
See this post for an answer - you may need to follow some of the links for more explanation.
http://archicad-talk.graphisoft.com/viewtopic.php?t=35888
alemanda
Thank you very much!!!
I solved my problem.
It was enough to change the parameters bShowCasingOnLists in the macro WallHoleframing.gsm and that's it
Why doesn't GS implement the option to show or not the casing/sill/board in the lists for doors and openings?
AC27 latest hotfix
Win 11 Pro 64bit
