ā2016-05-31 06:06 AM
ā2016-05-31 02:21 PM
m4hdi wrote:It does have a Find & Select palette, so you can select the 2D Objects by name, then open the Object Settings dialog box and change them to a 3D Object.
Since ArchiCAD doesn't have a "find and replace" command and I needed to replace 2d objects from autocad with 3d objects in archicad
ā2016-06-01 08:45 AM
David wrote:Thanks
ā2016-06-01 03:53 PM
ā2016-06-02 02:48 PM
