publishing PDF's
howdy
we have been having publishing to PDF issues on and off for a while now
most recently, we purchased a new iMac with OSX 10.10 & 32gb RAM
we are running archiCAD v16
when publishing to PDF we are having the following issues:
- publishing to the local HDD there are no issues
however, when publishing to a mounted sharepoint (OSX 10.6.8 server, with sharepoints via AFP) we get the following:
- publisher progress window opens and it looks "normal"
- goes down thru each layout, publishes it, with each layout showing a file size when done
however, i check the file on the server it is 0k and is not openable
we have no issues copying files / folders from the machine to the server in the finder, opening and saving archiCAD documents from the server, just this one weird publishing issue
any help / insight greatly appreciated
thanks
yukioMishima
2 Replies 2
The following Helpcenter page:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-10-yosemite/#Compatible_Arc...
says:
ArchiCAD 16 and older: major issues, upgrade not recommended
Not supported versions:
ArchiCAD 13-16 version can run on Yosemite, though these were designed to work well with older versions of the operating system. As a result there is no technical support for operating system specific problems, like the ones explained in this article.
laszlo
thanks for the reply
yeah… i had seen those caveats
on the whole, not having too many issues, this PDF being the main one
so, was hoping there might be a solution / workaround
thanks again
yukioMishima
