"Load bearing IFC property" for Stairs sub-elements ?
davdelven
Hello.
Does someone test in AC21 with the new stairs tool (I guess is the same tool technology as current "curtain wall") the possibility to assign a "load bearing IFC property" for structural function sub-elements, at least, in "stairs" ?
I've attached an screenshot of "GS help guide" talking about this current constraint.
Thanks in advance
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
4 REPLIES 4
davdelven
I also attach 1 screenshots showing the current constraint in AC20, i.e. with Curtain Wall
davdelven
And our wish with any kind of structural function elements in our model (beams, walls, STAIRS, RAMPS, CURTAIN WALLS, roofs, slabs...
Te "Structural Function" parameter can be set only for the whole Stair, but not for Stair sub-elements such as Flights, Landings, Treads and Risers.
davdelven
I see. It would be very good to be implemented next future in order to approach Archicad modeling to real BIM workflows, durint the whole building life cycle.
