rotating elements in 3D
In archicad 19 - there was a function where you could rotate and split elements in 3D - but I'm not sure here to find this on archicad 20.
Im not talking about rotating elements in 2D, but rotating the element, such as a wall for example, and rotating it on its axis.
5 Replies 5
Was it converting the element to a morph and then rotating it?
Hi - no I'm pretty sure it wasn't that
This is the menu in archicad 19 (Objective -> tools -> rotate)- i wonder where it is in 20. In Archicad 20 i don't have the objective menu
Objective is an add-on from CADimage.
http://www.cadimage.com/Tools/Objective
If you already have it for 19 I don't know if this allows you to upgrade for the 20 version or if you need to purchase it again separately.
I don't use it so not sure how the licensing works.
It'll be under the Cadimage menu if you have it (and are using the Cadimage based Work Environment)
