saving archicad drawings to PDF's
Does anyone know a way to save archicad drawings as PDF's for publishing on a web site ?
New help !
4 Replies 4
Eduardo Rolon
If using Mac OS then print -save as pdf
If using Windows you need to either
1)adobe acrobat to print to as pdf
2)install the pdf writer that comes with AC
3)create a postscript printer -print to file (as an EPS) then open in photoshop or illustrator and save as pdf
4)get all files in PM and publish to eps and follow #3
5) save as dwg and open in illustrator (or CorelDraw) and save as pdf
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you for your help. To clarify, I have Mac OS 9.2.2, w/ archicad 6.0v5, I know how to print the document, but not how to publish it on the web as a PDF.
Eduardo Rolon
I have not used OS 9 in a long time but in OS X when you choose print you have the option to save the file to pdf
AC29 US/INT -> AC08
Eduardo Rolon
If you mean that you already know how to create the pdf but not how to upload it to a website or create a site then you might check the .mac tutorials at apple.com
AC29 US/INT -> AC08
