saving from AC19 to Sketchup - SLOW
alemanda
Why the export from AC19 to Sketchup is so slow?!
I have a model with 325K polygons (not so much indeed) ... and It's working for 1 hour and half and it didn't finish yet.
Is it normal?!
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Katalin Borszeki
Hi All,
We have exchanged a couple of Pm-s with alemanda, and as it turns out the reason was caused by heavy polygon count created by an excessive amount of detailed doors. It so seems that the problem was solved. Tx, kata
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Katalin Borszeki
Hi All,
Regardless of this one specific case, I would like to let all of you know that we are planning to release a new Add-on for ARCHICAD 20 that would greatly optimize the Sketchup export. TX, k
Katalin Borszeki
GRAPHISOFT
