saving to .skp extension - Sketchup
Is there a way to save or export out of archicad 12 to a .skp extension?
Thanks for any help,
Michele
6 REPLIES 6
Eduardo Rolon
Save from the 3D Window to either DWG, DXF, 3DS and Import in SketchUP.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
So you can't save directly to .skp extension, correct?
Thanks,
Michele
Eduardo Rolon
You can also download the sketchup addon if you want but since I am on Mac and it is not available for us I don't use it. Check under Help for either add-ons or goodies.
AC29 US/INT -> AC08
another Moderator
Thanks for the help. I see it checked in my add-on manager but I'm not sure how to "activate it" I tried to go to a 3D window and saveas but I still don't get a .skp option to save it out as. It says it's a "tool" kind of add-on and I don't know it thats means anything as to how to "Activate it". Thanks for your help though!
Laura Yanoviak
AFAIK, the SketchUp add-on doesn't allow you to Save As a SKP file. We usually Save As a DWG from the 3D window as Eduardo recommended.
THanks for all your help, I found a way around it. I upload it to google 3D Warehouse out of a 3D window. It works great! You can then download it as a sketchup file.
Thanks,
Michele
