2007-01-07 12:19 AM
2007-03-13 12:46 PM
2007-03-19 09:55 AM
2007-03-19 11:08 AM
gkmethy wrote:Having moved the Schedules into the PLP file (which solved the dissapearing Schedules problem) I found that any Storey that had more than 100 doors in it the Interactive Schedule would "miss" 10 or so dooors from ID 80 to 90.
We have recently got notice of similar problems . To help us troubleshoot, please contact your local tech support and send them the files that have this problem. Thanks for your help!
2007-03-19 11:18 AM
2007-03-19 12:17 PM
2007-03-19 06:27 PM
gkmethy wrote:I know it's a little off-topic.... why not? It seems like it would be easier to save a GDL file to a previous version than it would be save a PLN to a previous version.
... if you used AC 10 library parts, the can not be converted back to 9 format. (GDL is not backward-compatible)
2007-03-19 07:17 PM
I am having the same problem.same here
2007-06-04 09:50 PM
2007-06-04 11:44 PM
fuzzytnth3 wrote:My reseller did come up with a solution to the schedule "missing" 10 or so doors which at the moment I can't remember what the solution was but I will have a rummage in my e-mails at work and post the solution later.
