scheduling zone flooring
I'm putting together a finish schedule and i'm having trouble finding the "flooring" parameter in the zone parameters to list. I see it in the zone stamp settings for the zone, but I can't seem to find it in the list of available parameters in the schedule. Can anybody point me in the right direction? Thanks!
1 Reply 1
In the Fields panel of the Scheme Settings Dialog, click the down-pointing arrow portion of the Add button and select the Add Object Parameters command.
Then you will need to find this parameter of the Zone Stamp object and add it to the schedule.
Step 4 of this article shows it with another parameter. It is an older article but the principle is the same:
http://helpcenter.graphisoft.com/tips/cost-calculation-using-interactive-schedules/#Step_4_Open_the_...
