2004-10-16 05:53 AM
2004-10-16 06:06 PM
RandyC wrote:Try to load the 8.1 translator that is provided with the 9, only not loaded by default and check.
I import Survey dxf files ( converted from total stations )
these files have very small lines - less than .0001 m that show as dots
with Archicad 9 these lines - dots are no longer imported .
I cannot find any setting in the translator that allows these points to be imported ! Point numbers and descriptions come in but not the points
can anyone advise ?
2004-10-16 06:30 PM
2004-10-18 03:19 PM
2004-10-18 06:14 PM
RandyC wrote:In the most suspect place - GOODIES folder, subfolder called DXF-DWG 2K In-Out. In my Int installation, it also contains 3dsIn, Profiler, etc ... all usable stuff. Warning - it handles DWGs only of AutoCAD 2000 flavour and older, so no 2004/2005.
where would this translator be stored ?
2004-10-19 02:30 AM
2004-10-19 02:14 PM
RandyC wrote:Attach a ZIP-file.
Sorry Djordje . I tried that one as well. Still doesn't work--- no points or lines show up.
I would love to send you a file that can be opened in Version8 but not in Version9 , but I cannot attach dxf files in this forum.
Randy
2004-10-19 02:28 PM
