2008-05-04 12:37 AM
2008-05-06 01:42 AM
2008-05-06 07:54 AM
any one know why when i'm apply the material to the object its not showed in shaded windowMaxwell is an external rendering engine, it works seperately from archicad. If you want to see the maps in the shaded window you should also create a similar material for the Internal renderer (IR), & load the same image into it. That will enable you to resize how the image will be displayed from within archicad. IE alter the UV coordinates.
