2004-06-02 04:42 PM
2004-06-02 05:20 PM
jazzdude wrote:How about using a printer driver which generates PostScript and specify that the printing output should go to a file?
In Archicad 8.1 how do you save to EPS as it is not in the supported list in save us, nor is it in the publisher list.
2004-06-02 05:28 PM
2004-06-03 09:20 AM
2004-06-03 12:06 PM
2004-06-03 01:07 PM
Petros wrote:Yes (at least I assume it is still possible in PM3).
Publish as encapsulated Postrcript from Plotmaker?
Petros
2004-06-03 01:10 PM
Matthew wrote:It usually works on PC too. You can install just one of the default printerdrivers and set it to print to file. The file will be named file.prn and if you change the name to file.ps it is usually a valid PS-file.
You can also print to a file from most (if not all) Postscript printer drivers. This is standard on Macs; not as common on PCs.
