schagemann
translator error message (-2130312712)
does anybody know what the following error code means:
-2130312712
it occurs upon opening a dwg right after setting up the translator (while ac converts/processes the drawing).
although the file then seems to open correctly we do experience positioning problems (even if the file is moved to the exact coordinates it will not come in at the right/same position when hotlinked into another file) and wonder if this is related to the error message.
daniel.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
0 Replies 0
