wall accessories (goodies)
I added the accessories add-on to my AC18 so I could use the wall framing feature in goodies. It works fine as far as displaying the editable framing. But when I run the lumber pack component list that is supposed to calculate lumber quantities / cut list, I get this error message:
"Database name 'AC_10_INT' not found
at line 87 in the Property script of file LumberComponents_11.gsm."
Does anyone know how to find the LumberCompnents_11.gsm object? Do I need to change AC_10_INT to AC_18_INT in the property script, or is it more complicated?
Ideas?
1 Reply 1
Andy Thomson
Mentor
Did you get anywhere with this? Did you load a migration library - or search for that script/object in an older library to co-load? Of did the name change work?
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
