wall surface calculation
is there any possibility to calculate the wall surface using zone height instead of walls height?
My walls go up through the slab and end on the next floor level. And when I try to calculate wall surf. (using zone list) there is a value for the whole height of the walls. I don't get how can I achieve the result I need without tearing walls by slabs. Please help.
1 REPLY 1
Hi:
Probably is too late.
But, I think is a better idea use the individual property add to your wall.
So, in that way, is not important the layer or the floor in your project.
AT the end, using the General Element List, will be soon and easy get the right results.
