3d window settings
peter spellman
I am trying to figure out if you can turn off the lines surrounding
shadows in the 3D window.
I am using the internal engine in shading mode w/hatching and
sun shadows on, but would like to eliminate the black lines around
the sun shadow polygons. (see attached view)
Any help would be greatly appreciated.
Peter
In the 3D Window Settings with Internal Engine method selected you have Vectorial Sun Shadows options bottom left of the dialogue - set this to Contours Off
peter spellman
Thanks for the reply Stuart. It is nice when it is that easy.
Peter
