Copy saved camera view from one file to another.
Hi, can someone please walk me through exactly how to copy and paste a camera view in to another project? I can't seem to make it work. Thank you in advance!
1. In the Perspective View in 3D, use the View > 3D Navigation Extras > Put a Camera into the Path menu command, which will place a Camera.
2. Go back to the Floor Plan, select the Camera, and Copy it to the Clipboard.
3. Go to the other Project File and use the Paste command to paste the Camera into the Project.
Thank you Laszlo!
