Dimensions in GDL objects
Hello, there is a way to add 2D GDL object dimensions, length, width and level dimensions.
I want to size a rectangle ( for example ), if I change variable A then the size in 2D will change automatically.
Thank you!
3 REPLIES 3
Lingwisyer
Guru
Just used A to define a variable when drawing the rectangle?
rect2 0, 0, A, B
If it is 2D, there is no "level dimension"...
If you mean you want a scripted dimension line, then no.
You will have to script the lines, markers and text yourself.
Thank you !
Learn and get certified!
