How to hide lines on an arc?
HI! How can I hide the line on the arc when I use the PYRAMID command? I have tried to modify various parameters and failed.
pen 1
material 18
addz 0.7
CUTPLANE
del 1
PYRAMID  8,1,1+4+8+16,
                -0.1, -0.05003063326032,     0,
                -0.1,         -0.1,     	 0,
                 0.1,         -0.1,     	 0,
                 0.1,          0.1,     	 0,
                -0.1,          0.1,     	 0,
                -0.1, 0.0461786407767,       0,
        -0.1168562960013, -0.001925996241812,    900,
                   0, -141.3781634212,   4000
cutend
3 REPLIES 3
This works if you want to keep it as a pyramid, but maybe there are other solution with RULED or SWEEP?
Add a 'fake' node before the curve (as close as you can get it), then change the status of the curve edges.
Thank you for your method, I converted the arc into a line.
Yes with many straight lines you can control their visibility (status) individually.
Just make sure you have enough lines for a smooth looking curve.
With an ARC you can just change the RESOLution value to increase/decrease the number of segments.
Learn and get certified!
