Design forum
Input data from text file narrow down in object
JGoode
Hello,
I am trying to work the best way of inputting data from a text file and then being able to narrow the list down within the object.
Thanks
ArchiCAD 23
Windows 10
1 REPLY 1
There are several way to input from/output to files in GDL. You should check the GDL Reference Guide. You can work with TXT files, "Data Files" (you define the format in the file, but basically a text file), XML files.
After you input that data you can work with array and I guess you can narrow down the array into another array that contains only those items that fulfill your criteria.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
